Forsakenishere
Poor speed and signal on super hub and nat2 on wired connection
I think my super hub needs an upgrade. Since the speed boost upgrade my super hub has gone into melt down signal is poor the speed has now halfed and my wired connections for PC / PS4 have NAT 2/3 restrictions. Is there a firmware fix for the old school super hub 1 or can I get a super hub upgrade
  • 3.88K
  • 120
  • 203
Forum Team (Retired) Adam_L
Re: Poor speed and signal on super hub and nat2 on wired connection
Hi Forsakenishere,
Thanks for letting us know about your poor speed and signal issues, I apologise for any inconvenience caused.
I have tested the connection from here for you and I can't see anything out of the ordinary no errors or time outs inside the Hubs logs, and all of your power levels are within the preferred ranges.
Are you still having these issues? If so, please run a speed test with your Hub running in modem mode, connected directly via ethernet cable to the computer running in safe mode with networking, and post the results here for us to see.
Speak soon,
Adam.
