HellRiaser's avatar
HellRiaser
Hub 3 in modem mode showing on WiFi
I have just upgraded my WiFi and put the  hub 3 in modem mode. It was all easy enough and is working fine.
However I'm still seeing the Hub 3 as a WiFi network. Even forgetting the WiFi still has it showing as an available WiFi network. I can't join it or anything and it does sometimes disappear. I don't want another WiFi signal congesting the new signals.
Is this normal and will it effect the new WiFi? Also is it a security issue, where someone could find that network and use it?
    • HellRiaser's avatar
      HellRiaser
      It is! I've turned off the modem/old router and it's still showing up!  It's quite a unique name
      • legacy1's avatar
        You likely don't have to worry now now that you don't use that SSID
  • Tudor's avatar
    Have you any power line adapters? Have you got an iPhone/iPad as Apple devices save every SSID you have visited.
      HellRiaser
      We have an iPhone and a Mac. But it's also showing up on my android phone. Even when the old router/modem is turned off.
