BHammar
Just joined
Dropped Broadband Signal
For about two weeks now our broadband signal keeps dropping out. First it was only once a day, but now it is several times per day. First I just unplugged the router, waited 30 seconds and plugged it back in and the signal would come back. Now I have to try several times to make it work again, and several times per day.This makes nonsense out of your service.
What can I do to get this fixed?
Bengt
  • 2.96K
  • 378
  • 939
Re: Dropped Broadband Signal
Hi Bengt
Are you using a wired Ethernet connection to the VM hub or a wireless connection? Wireless is easily disrupted by a number of external factors, so knowing if a wired device drops out helps to pinpoint if the issue is with the wireless or your line.
If you go to http://192.168.100.1/ to get the VM hub GUI. Don't login but instead click on Router Status which is either a button in the top right of the screen or a text link at the bottom of the screen depending on which hub you have. Click on the Downstream, Upstream and Network Log sections and copy & paste the figures from those screens and post them here, don't worry about the formatting or you can post screenshots if that is easier. Be careful to edit out or obscure any reference to your WAN IP in the log to protect your privacy.
The community can have a look for you and see if anything in the figures looks wrong and advise accordingly. Or you can wait for the VM staff to pick up this thread (can take up to a week) and run checks on your line.
______________________
Scott
  • 3.88K
  • 120
  • 203
Forum Team (Retired) Adam_L
Hi Bengt,
Thanks for letting us know about your broadband dropping signal, I apologise for any inconvenience, I'll do my very best to help resolve this for you.
I have run some diagnostics from here and I can see that all of your downstream power levels are too low, in order to get this sorted an engineer will need to attend and investigate this further for you.
I will send you a PM (purple envelope at the top) detailing what's required to proceed with making the booking. Please respond to me there and I'll ensure this gets booked and secured for you.
Take care,
Adam.
