black_arab
Default VM SSID
Hello there,
I have recently upgraded to the SH3.0 and when I try to configure the router settings no matter what I do I cannot get rid of the default SSID connection.
I can change it on the main screen to my own and then change the network key.  I can make separate 2G and 5G connections, again with my own network key but then when I restart the router and go to connect any of my devices the default i.e  VM4152355 is still there, plus I'm still able to connect to it.
I know recently I was informed of some wifi anywhere service that if I signed up I was also allowing others to connect to my router in return, but I declined that.
Please help.
regards
Bob Godfrey
  • 10.64K
  • 312
  • 654
Re: Default VM SSID
Hey Bob,
Sorry to hear that you're unable to change your SSID, that's certainly an odd fault and it sounds like we'll need to arrange a replacement.
I'll drop you a PM (purple envelope, top left) to confirm your address.
Speak with you soon,
Take care.
Heather_J
