Ask a question
The Sorcerer’s Apprentice
Increase Mobile Phone Signal in my Home
I would like to know how to increase my mobile signal within my property.  I am getting fed up with lost signal and was wondering what Virgin has to offer.  Mobile Phone Signal repeater?
One to Watch
Re: Increase Mobile Phone Signal in my Home
I am looking for the answer to your question months after you posted.
First of all, apparently (by ofcom website) mobile signal repeaters are illegal and it can cost you up to 5,000 GBP and/or 51 weeks in jail.  Because the frequency spectrum is owned by (O2, Orange, T-Mobile, Vodafone, Three respectively) and anyone else is forbidden to emit in the same spectrum(s).
Second of all, If you are a:
Vodafone Customer, you can buy a Sure Signal box connect it to your home internet connection and that will emit a local small Vodafone Signal (this device is also called femtocell device), for this to work you need internet connection (BT, VirginMedia etc.).
Three's Home Signal is the same thing.
O2-PayMonthly have an app called TuGo - which does kind of the same thing over your WiFi.
EE, T-Mobile and Orange Customers have the Signal Box, but unfortunately even though Virgin Mobile uses their signal, it doesn't looks like this box will help us.
If you got a soultion for a bad signal at home with Virgin Mobile than please post it.
For Virgin: Please get a box or app together.
The Sorter
Virgin will be releasing an app soon called Smartcall that helps when you have little or no mobile reception at home.
http://customer.virginmedia.com/smartcall/
One to Watch
Thanks for your quick reply.
That is very good news.
HOWEVER
Something is not too clear for me.
I need something (like this app) to be able to use my Virgin Mobile indoors.
This SmartCall it only talks about "your Virgin Home Phone" , and getting the Home Phone minutes on to your mobile and even abroad.
It doesnt' really talks about a Virgin Mobile. (as far as I can tell from the link you gave me)
I don't have a Virgin Home Phone - neither intend to get one ; that would be another phone number and everybody knows my mobile number.
So my question would be:
Am I misunderstanding something (I hope I do)?
Or this app will be for Virgin Home Phone (Landline) as well as Virgin Mobile ?
Thank you,
Elemer
Mythical
Why woukd the ee box not work?
One to Watch
I am not 100% sure it wont work.
I.just dont know exactly.how they work.
My guess is that they use the same frequency as EE , and to authenticate you (who you are what can you call and so on) they connect this SignalBox to the EE server through the internet.
If this solution would work for Virgin Mobile than I will get one tomorrow.
Do you know.for sure that this will work ??
Elemer
Mythical
I dont know sorry, but if you find out please let us know
Hi Elemer
Happy to help with this :smileyhappy:
You're quite right that the SmartCall app we're developing is to be used in conjunction with a landline and not mobiles at the moment, although it does use the WiFi on the mobile to make calls through your landline.
I can appreciate this isn't something you will be able to take advantage of at this time.
As EE's Signal Boxes haven't been tested with Virgin Mobile, there's no guarantee it will work. For more information on this, have a look at this thread.
Many thanks,
Mark Y
Help & Support Forum Team
Problem Solved?Fault with your service?We did warn you!
One to Watch
I am very dissapointed to hear that.
I don't see much point on having an app on your mobile to use your landline minutes, like home.
It would be much more usefull having the same app but for Virgin Mobile Customers. When I don't have signal in my home but have WiFi I could still use my phone (people could still reach me).
Hope Virgin will make this app avalaible for Mobile customers as well.
PLEASE !!!
Making Waves
From what I'm read from other queries on this forum you can only make outgoing calls using the smart app and not recieve them, SMS texting does not work either.
