Message 1 of 2 (125 Views)
Wireless connection keeps failing.
For 2 days now I have not been able to use my wireless connection properly. it came back for a bit last night but its gone again now.
Here's the kicker though. I can't ring VM because the phoneline I reported as faulty 2 months ago is still not repaired
I've done the master reset, turning off turning on and everything else but it keeps failing.
Very poor service, even the VM twitter ignore me too.
  • 5.73K
  • 116
  • 292
Message 2 of 2 (105 Views)
Re: Wireless connection keeps failing.
Hi rarthetiger,
Please take a look here at ways to resolve your issue.
Regards,
John O
Help & Support Forum Team
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as an Accepted Solution? You can also help other users find useful posts by Tagging them with keywords.
If you are new to the forum, please remember to search the forum before posting your question.
