  • 50
Message 1 of 2 (183 Views)
Slow speed and IP address change in Modem Mode
Hello
I have recently purchased a Cisco RVS4000 VPN Router and I have a slight problem I wish an expert to help me with.
At home I have a 100Mbps internet connection which gets a result of around 80-98Mbps on the speedtest.net .  However, when use the RVS4000 with the Superhub in Modem mode I can only achieve 20Mbps downstream and 9Mbps upstream.   I am using Cat 6 cabling for everything with Gigabit ports.  The QoS / bandwidth settings are disabled on the new device.  The Cisco is set in Gateway mode as opposed to Router mode.
Also, when I switch to modem mode my IP address changes to a VM 82 range address
Any ideas what could be causing the slow down and is the IP address change normal?
Chris D
Community elder
  • 7.33K
  • 215
  • 570
Message 2 of 2 (181 Views)
Re: Slow speed and IP address change in Modem Mode
[ Edited ]
If it has IPS enabled try disabling it.
------Die-hard direct connection modem user---Because newer is not always better Super hubs 1, 2 & 3 could have been built better the years go by and we can't see the mistakes that were made to make things right. Use modem mode If I could offer you only one tip for the future, modem mode would be it. BQM, Outgoing ports test
