Message 1 of 2 (356 Views)
DIR-615 constantly drops connection to wired and wireless PCs
I have had a DLink DIR-615 D4, Firmware 1.00 VG, since 11/2010
It is constantly dropping connection to both a wired PC and a wireless laptop requiring a re-boot and has done this since it was acquired. This can happen up to five times in one night.
Usually all the lights remain green when the connection is lost although very occasionally the wireless light will go out, or the power and internet lights will turn orange and the wireless and pc lights will go out.  There is no issue with the modem that I am aware of, the correct lights remain on.
I am unable to log on to the router when this happens, getting the page not found message in my browser.
I have had enough of this pile of junk and wonder if it is possible to get a router that does what it is supposed to, that is just sit there and work without needing a **bleep** break every hour or so.
Would a replacement router from Virgin be worth it or are they all this bad?  Would a firmware update be preferable?
All Replies
  • 2.79K
  • 61
  • 156
Message 2 of 2 (331 Views)
Re: DIR-615 constantly drops connection to wired and wireless PCs
Hi JustsoAJ,
I have ordered a replacement router to be delivered to your home address in the next 3-7 working days.
I apologise for the inconvenience caused by the faulty router.
Kind Regards,
Neil D
Help & Support Forum Team
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as a Helpful Answer? You can also help other users find useful posts by Tagging them with keywords.
If you are new to the forum, please remember to search the forum before posting your question. Please don't send private messages directly to the forum team unless they ask you to, post your issue to the forum first.
