on 08-05-2023 11:36
I have changed the picture settings on the virgin box from 4k to 1080p but still the problem persists. I've contacted Virgin and they have sent an engineer who told me they always have problems with Samsung TVs - he went through the Samsung setup menu and got the picture back, but the very next day same issue again.
Never had any problems with the TIVO box which had been connected to 2 different Samsung TV's in the past. Personally I think it could be newer software on these TV boxes that might not be compatible with my TV. The TV is a Samsung 4k 59 inch and is about 4 years old. The TV firmware is up-to date. If this cannot be resolved I will have to cancel.
on 08-05-2023 13:19
Does "no picture" include V6 menu system & EPG - can you view this?
When you say about turning the box off overnight, do you mean mains power (bad idea) or just standby? If the latter, what are your power-saving settings?
I do suspect an HDMI handshaking issue here - have you eliminated the lead & TV port by trying alternates?
08-05-2023 13:24 - edited 08-05-2023 13:28
I get the EPG menu - etc on start up - the picture is in the preview box but as soon as you select a channel - audio only.
I do switch off mains at plug for tv and box overnight night - cables been changed - Virgin engineer fitted new highspeed hdmi.
on 08-05-2023 14:37
VM's TV boxes are designed to be left on 24/7 and updates are often pushed out overnight. Having to download those each time you power on will very likely cause some issues sooner or later - try using the power-saving options and see if that makes any difference. At the very least, it'll be something eliminated.
on 10-05-2023 14:46
on 16-05-2023 13:33
Hi Yes - I leave the box on standby - works ok now - doesn't like being shutdown completely
on 18-05-2023 14:19
Hi @Gaz6477,
Thanks for coming back to us and keeping the thread updated on this issue!
Glad to hear that the TV box is working for you now. If you come across any other issues, please come back to us so we can help further.
Thanks! 😊
