chris361's avatar
chris361
6 months ago
Sound Quality
The sound quality on TNT sports ultimate is appalling, any advice regarding sorting this out?
  • roy247's avatar
    roy247
    6 months ago
    I have an LG TV and soundbar and don't have any problems with the sound quality on TNT Sports Ultimate apart from the fact that it does occasionally momentually drop off the Atmos but then come's back, this has been a long term problem and been posted about by others.
  • Roger_Gooner's avatar
    Roger_Gooner
    Try another HDMI port and if that doesn't work try another HDMI cable.
  • In what way is it appalling.
    If you have a soundbar and want to receive Dolby Atmos then you need the 360 set to follow content, if you are just using the TV speakers then using one of the PCM settings might be better.
    • chris361's avatar
      chris361
      For want of a better description it keeps breaking up. The sound is delivered though the TV's speakers(LG oled) the HDMI cable is fine. This is the only channel that is affected. Up until 4 days ago it has been fine for the last 12 months.
      • roy247's avatar
        roy247
        Hero
    • Daniel_Et's avatar
      Daniel_Et
      Hi fizz, thank you for your post.
      In order to discuss this with you further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
      Regards,
      Daniel
  • fizz's avatar
    fizz
    Fibre optic
    @daniel_et
    I have replied to your PM but I don't understand why I need an engineer when I have no issues whatsoever with any of my services or either of my v6 boxes and you have not explained why you need to send an engineer either?
