on 09-06-2023 12:00
My phone continually changes region. This leads to phone numbers being changed to a different format and meaning I am unable to use my phone to call people.
I have changed the region on my phone to us as per advice from a virgin staff member on the phone. However I shouldn’t have to do this and this means my dates etc on the phone are in US format. Please advise how this can be fixed.
on 09-06-2023 12:31
Hi @Lucyb90 👋.
Thanks for reaching out to us on this matter. Sorry to hear you are having mobile phone issues 😢. The formatting of the number should not cause the phone not to dial out. It is based on where and how the phone is setup also. We would advise that you look into your account either Google Play or App Store to ensure that your account is based in its country of origin. Then ensure that the network settings are have been checked and reset if needed. Then the handset itself, its origin when being set up may be set to english USA for language which will change the formatting of contact numbers.
These will help 👉 iPhone Guide
👉 Samsung Guide
Hope this helps.
Sabrina
09-06-2023 13:12 - edited 09-06-2023 13:13
If it is an iPhone it is a common problem that has been going on for years, ever since Virgin got Belgian programed SIM cards.
Using SIM Toolkit and setting the roaming settings to National rather than Automatic, was a cure, but I believe that facility has been removed from many SIM cards pending the move to O2 and Virgin Mobile's closure.
