on 19-03-2024 10:25
I have had my Stream Box Since October 23 with no issues. The last week i had Audio disappear when using Netflix. This week the audio has now disappeared from other apps too. I have no issue with Live TV or Youtube so I imagine there is a fault with the box?
on 19-03-2024 11:04
Hi @abijayne152
Have you tried rebooting the Stream box?
Are you using a soundbar? If so try removing the HDMI or optical cable from both the Stream box and soundbar and turn off the equipment, reinserting the cables and then turn the equipment on again.
on 21-03-2024 17:13
Hi abijayne152,
We're sorry to hear you've had some issues with your audio on your Stream box.
Please give the suggestions provided by newapollo a try and let us know how things go.
Many thanks,
