on 09-12-2023 08:02
Good morning I have an issue with tnt sports ultimate on virgin stream the picture is great but I have no sound at all on this channel I’m usually pretty good with this stuff as I have a tech head of sorts but I just can’t get the sound on this channel to work at all
can anyone help please
many thanks Freddie
Answered! Go to Answer
on 11-12-2023 11:52
Hi ubberhead100,
We're sorry to hear you've been having an issue with the sound on the TNT channels.
I have sent your issue over to another support team who will review your issue, the estimated fix time is up to 5 working days. Where possible they'll fix the issue remotely, but will contact you if they need any additional information.
Apologies for any inconvenience and keep us posted on how things go.
on 09-12-2023 08:16
on 09-12-2023 08:22
Tried this my friend and the same thing with the stream box but no joy it’s really strange it’s just this one channel everything else works perfectly
on 11-12-2023 11:52
Hi ubberhead100,
on 11-12-2023 11:56
Good morning Sir many thanks for help the sound has started to work this morning just randomly from no where I ran the demo the channel was playing and it was working fine so maybe it was a broadcast issue but thanks for your help and time not really sure what the issue was or is
on 13-12-2023 12:11
Glad to hear the sound is working as it should be.
Any future issues or advice / help you need you know where we are 🙂
Matt - Forum Team
New around here?
