on 21-12-2022 19:11
Yesterday it would turn TV on and off and controlled volume, it did not allow me to acces home or any 9f the apps. Today it does nothing. I have tried pairing, I have held TV and zero and TV and rewind. I have tried new batteries. I have disconnected. There is a pale blue light on the stream box, a white light flashes on the remote if I press keys.
on 22-12-2022 12:50
I'm having the same problem. I've done everything Virgin Media have told me to do, but it still won't work. I checked the service status in my area and there's something wrong with virgin TV, but I'm not sure if that would affect the box as it's a streaming box rather than tv. If that is the problem though, Virgin media said it won't be fixed until 29th December!
Have you been able to reconnect your remote to your box yet?
on 27-12-2022 09:40
Hi barry1106,
Thank you for your post.
Sorry to hear of the issues you've been having with your remote - sounds like you have done everything we would advise to help here. How are thins with the remote at the moment? Alternatively if this continues to not work, you are able to order one from here: https://www.virginmedia.com/support/help/tv/streaming/journey/order-new-remote
Cheers,
Ryan.
on 14-01-2023 17:56
i have the same problem as barry1106. stream box the remote control stopped working overnight and I can't do anything about it, and I can't order because I have a stream box for hub5, and this link doesn't work for me. please help, because I can't use the box for 3 days now
on 14-01-2023 18:20
Hi @lukawski
Try <<< this link >>> to order a replacement remote in either a different brower or an incognito window.
Also have you tried different batteries, also re-pairing the remote?
Point the remote at the Stream box and then press the TV button and 0 at the same time for 10 seconds.
You can also download and use the TVGO app as a temporary remote. There are download links <<< on this page >>>
on 14-01-2023 18:37
Unfortunately we can not offer you a replacement TV remote for the TV box you have. The TV remote is either no longer supplied by Virgin Media or our current stock levels are low.
on 16-01-2023 20:11
Hi @lukawski,
Welcome to our Community Forums! Thank you for your post and I'm sorry to hear that this is the error you're seeing!
Can you please confirm if you have a Stream Box, or a different TV box that you're having issues with?
Please let us know so we can assist you further.
Thank you.
on 16-01-2023 20:41
I have a stream box and hub 5. month ago I signed a contract. Everything was fine with the Stream Box until last weekend. Since then, it has not worked. can I replace it?
on 17-01-2023 01:17
Hello I've had the same problem I tried everything, but I've managed to pair my remote to my stream box by pressing and holding the power button on the front off the stream box for about 10 seconds then a message came up on my screen (top right) that my remote is paired to my stream box again...
It helped me so I hope it helps you..
on 17-01-2023 16:48
It works. thank you for the hint. I wouldn't have thought of doing it this way.
