on 12-04-2024 21:40
Good evening
I have just joined virgin media and it said i was ok with setting up the equipment myself. However I currently have sky fibre and virgin I believe still use the coaxial connection.I have booked an engineer visit as i do not have a virgin socket and would not be able to set up myself.
I only have an old box (see picture) and it says SKY on it, would virgin plug into this and work?
on 12-04-2024 22:22
Not you cannot use any of those connections. The VM technician will set it all up for you.
on 13-04-2024 22:38
Hi Tudor
Thankyou for your reply. But that is the only connection that is in my 5th floor flat!
My other connection is SKY fibre that i have had for 18 months since i moved in.
on 13-04-2024 23:04
In that case the technician will need access to the service room to change over the connections.
on 16-04-2024 09:51
Hi porkpiepete
We're sorry to hear you've been unable to do the home install due to a missing connection.
The engineer visit should resolve this 🙂
Please do let us know how the visit goes.
Vikki - Forum Team
