08-06-2023 11:53 - edited 08-06-2023 12:07
I've taken notice that my downstream power levels are high since my last virgin media engineer visit (about a year ago) but never questioned if its a problem but will now. I read somewhere that it should below 10 and upstream power over 34. Would I need an engineer visit again?
1 | 186750000 | 15.4 | 38 | 256 qam | 7 |
2 | 138750000 | 15 | 38 | 256 qam | 1 |
3 | 146750000 | 14.5 | 38 | 256 qam | 2 |
4 | 154750000 | 15.4 | 40 | 256 qam | 3 |
5 | 162750000 | 15.4 | 40 | 256 qam | 4 |
6 | 170750000 | 15 | 38 | 256 qam | 5 |
7 | 178750000 | 15.4 | 38 | 256 qam | 6 |
8 | 194750000 | 15.5 | 38 | 256 qam | 8 |
9 | 202750000 | 15.3 | 38 | 256 qam | 9 |
10 | 210750000 | 15 | 38 | 256 qam | 10 |
11 | 218750000 | 14.3 | 40 | 256 qam | 11 |
12 | 226750000 | 14.6 | 38 | 256 qam | 12 |
13 | 234750000 | 14 | 38 | 256 qam | 13 |
14 | 242750000 | 13.5 | 38 | 256 qam | 14 |
15 | 250750000 | 13.5 | 38 | 256 qam | 15 |
16 | 258750000 | 13.5 | 38 | 256 qam | 16 |
17 | 266750000 | 12.5 | 38 | 256 qam | 17 |
18 | 274750000 | 13.8 | 38 | 256 qam | 18 |
19 | 282750000 | 14.5 | 38 | 256 qam | 19 |
20 | 290750000 | 14.3 | 38 | 256 qam | 20 |
21 | 298750000 | 14 | 38 | 256 qam | 21 |
22 | 306750000 | 15.1 | 38 | 256 qam | 22 |
23 | 314750000 | 13.9 | 38 | 256 qam | 23 |
24 | 322750000 | 13.9 | 38 | 256 qam | 24 |
on 08-06-2023 11:53
1 | 30100000 | 32.8 | 5120 | 32 qam | 4 |
2 | 23600000 | 32.8 | 5120 | 32 qam | 5 |
3 | 36600000 | 32.8 | 5120 | 64 qam | 3 |
4 | 43100000 | 32.8 | 5120 | 32 qam | 2 |
5 | 49600000 | 32.8 | 5120 | 32 qam | 1 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 1 | 0 |
5 | ATDMA | 0 | 0 | 0 | 0 |
on 08-06-2023 14:19
Way too high. Either need adjusting at the street cabinet of a 10dbm forward path attenuator fitting, both are a technician’s job. Best wait for a VM staff member to get to your post.
on 08-06-2023 16:51
Downstream power should be between -6 and +10, Upstream power between 34 and 51. QAM on Upstream should all be 64. That's what I go by anyway. It's a decent yardstick for most circuits.
on 08-06-2023 17:48
Hmm thought so, will wait for a staff member.
on 11-06-2023 13:14
Hi rolandjp,
Thank you for your post. I'm very sorry to hear about the issues you've had with your broadband issue.
As it has been some days since your last post, I just wanted to check in about your service.
Are you still having issues?
^Martin
on 11-06-2023 14:21
Not having issues but as other members said power levels are not ideal and needs adjusting. Is an engineer needed?
11-06-2023 16:04 - edited 11-06-2023 16:04
Setup a BQM the hub can tolerate high dBmV downstream
Broadband Quality Monitor | thinkbroadband
I be more worried about your upstream
