3 weeks ago
We've had builders working in our flat & since they've finished the broadband has stopped working. We think it is the thin white cable that comes out of the wall that is damaged. How do we get it fixed and how much will it cost?
Thank you
3 weeks ago
Can you post up a photo of the damaged cable? What Hub model is it and what are the lights showing/doing?
Then call it in on the faults line on 150 (VM line) or 0345 454 1111 others and they will test your connection - if a fault is detected they will send out a Tech to sort it. If it does turn out to be damage "you" caused - then there is a standard fix charge of £25
3 weeks ago
The router is broadcasting WiFi fine but there is no internet connection available via the WiFi. The thin white cable that comes through the wall from outside then clips into the white box on the wall with a small green connector looks to me as if it is broken so we think that is where the issue lies
3 weeks ago
You have a Hub5x. You need a technician’s visit to rectify.
3 weeks ago
Hello Liz20
Sorry to hear of the broadband issues experienced, we appreciate you taking the time to raise this via the forums and welcome to the community.
From checking we can't see you contacting the team in regards to the connection issues, have these improved since your post on Monday? Please let us know if you need assistance with this as we're happy to help.
3 weeks ago
Thank you for your reply. I posted in order to find out how much it will cost us to book an engineer to come out to fix the problem as we currently have no broadband.
3 weeks ago
Hi Liz20,
Oh I'm sorry to hear this is affecting your services. I've just had another look and can see you've been able to arrange an engineer visit.
Let us know how it goes and if you need any further assistance from us here 😊
2 weeks ago
The engineer was very helpful thank you and it is sorted
