Volt Benefits missing on VM and o2
Jamcg82
Hi, been with both VM and o2 for over two weeks and no sign of Volt benefits on either platform. Can someone assist please? Thanks.
3 REPLIES 3
Jamcg82
Anyone from VM able to help?
Hi @Jamcg82
The info below is from the https://community.o2.co.uk/t5/Volt/Volt-Megaguide  page
You can opt in for Volt benefits from the My O2 app. Once you're in the app, go to 'Offers', then 'Supercharge your world with Volt', then tap 'See what you can get. From here, simply fill in the details you're asked for and within 14 days you should have your benefits applied on both your O2 and Virgin Media accounts.
Dave
The do's and don'ts.
I sent o2 a DM on Twitter. All sorted at o2 and VM in under 24 hours.
