on 08-06-2022 06:51
on 09-06-2022 16:31
Anyone please? Is it only the volt benefits i will lose?
on 12-06-2022 10:48
Good Morning @IainC86, if you were to cancel the O2 sim card, you would not longer be entitled to the Volt benefits.
Without an O2 account, the pricing of the Virgin Media services wouldn't be effected, unless you had Wi-Fi pods on your account - they would then be subjected to the monthly £5.00 charge.
Kindest regards,
David_Bn
on 12-06-2022 10:55
Thank you. The proble i have is already have an o2 subscription would defo go volt in future though, il cancel the sim meantime.
thanks for your help
on 12-06-2022 17:20
If you have an O2 subscription you can still have Volt.
My O2 phone is totally separate from my broadband but because both are registered to the same address I get Volt benefits.
