nicholaw2007
connecting virgin v6 box to projector
just had my brand new virgin tv box installed works fine with tv
however tried connecting to a projector all i get is a green screen
total nightmare!!!!!!!!!!
projector worked fine with sky box and youview
confused.com
  • 517
  • 50
  • 105
Cueball99
Rising star
Re: connecting virgin v6 box to projector
What box did you get, TiVo or V6?
I would guess if you have a V6 then it's a HDCP issue. Possibly the video format set on the box is fine for the TV but the projector, or hdmi cable, is not compatible.
nicholaw2007
hi,got the v6 box
is there anyway of sorting out?
was thinking of getting a netflix or something dongle for the projector so i can watch films etc
many thanks
  • 25.14K
  • 1.04K
  • 4K
get a fire tv stick for the projector. that would give you loads of stuff
