Annemarie2212
Virgin box no power
Hi my virgin box has no power. Was working fine yesterday morning. Tried the usual turning off and on and holding button. But no avail. All wires etc are plugged in properly.
Any ideas?
  • 9.95K
  • 1.1K
  • 4.74K
Re: Virgin box no power
Any ideas - yes, fuse blown?  Phone VM to tell them something is wrong so they can replace the box or power supply. You need a Forum post to tell you this?
Click to learn more about VIP
Use Kudos to say thanks
