  • 11
houndog787
Message 1 of 16
Sound problems
I'm having some issues with the sound output on my TiVo box. I have been using a LG soundbar and subwoofer for the past year so I've never had any problems however since my soundbar got damaged Im now using the speakers from my LG TV 4k TV and the sound when using my firestick is perfect ,the sound when using apps through my TV is again perfect but the sound when using channels on my TiVo box is well terrible. You can barely hear it and it has the oddest sound I've ever heard. No bass or nothing, very faint to the ear and kind of like an echo sound to it. It's barely watchable with this sound.
What is going on? Anybody got any ideas ? I tried messing about with the sound settings in the TiVo box menu but it's made no difference at all
  • 1.93K
  • 106
  • 219
Message 2 of 16
Re: Sound problems
Hi there houndog787,
Sorry you're having some sound issues there - very odd as you advise it's working ok for any apps you use; are these apps via the TiVo?
You advise you're using speakers from your TV; do you mean you're just using the TV itself for sound or do you have separate speakers?
Have you tried changing/checking the sound settings via the TV itself to see if that helps?
Let us know and we'll see what we can do from there.
Cheers
Katie - Forum Team
  • 11
houndog787
Message 3 of 16
Re: Sound problems
Hi Katie
Thanks for getting back so quick. Yes I'm using the speakers from the TV itself and the apps that sound perfect are through the TV not through the TiVo box. I have tried altering the sound settings in the TV but they are fine. The sound is fine from the TV when I use firestick or TV apps . It's just when I use the TiVo box channels that i notice a difference in the sound
  • 10.73K
  • 1.09K
  • 1.71K
Message 4 of 16
Re: Sound problems
Do you really mean "Tivo" - or V6? I believe the Tivo is not 4K capable (not sure if this would cause your issue though).
  • 4.98K
  • 350
  • 845
Roger_Gooner
Superstar
Message 5 of 16
Re: Sound problems
Are you saying that you've now got the TV connected by HDMI cable directly to the TiVo and that the TiVo's audio setting is Dolby Digital to PCM?
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 11
houndog787
Message 6 of 16
Re: Sound problems
Yes sorry it's the V6 box
  • 11
houndog787
Message 7 of 16
Re: Sound problems
It's the V6 box and yes it's connected via HDMI cable and the sound setting on the box says Dolby digital to PCM
  • 4.98K
  • 350
  • 845
Roger_Gooner
Superstar
Message 8 of 16
Re: Sound problems
And you also get bad results if the setting is Dolby Digital? It seems as if the TV is not processing audio via its HDMI inputs, suggest you contact LG. Or get another soundbar.
  • 11
houndog787
Message 9 of 16
Re: Sound problems
Yes it sounds exactly the same when I change it to Dolby digital. I have a firestick connected via HDMI cable to my LG TV and the sound when connected to my firestick is perfect so I don't think it's the TV. It all points towards it being something to do with the V6 box
  • 4.98K
  • 350
  • 845
Roger_Gooner
Superstar
Message 10 of 16
Re: Sound problems
Not proven, it worked when you were using the soundbar. How was it connected to the TV and V6?
