sean8050
Just joined
Ideas for Multi Room With Minimum Cables
I have recently installed a second TV in our 'snug', i have ran a power cable and socked under the floorboards and to the tv. It would be a massive effort to run the virgin cable in too from the current box to a second. Is there any wireless options?
Thanks in advance.
  • 15.64K
  • 1.63K
  • 3.52K
Re: Ideas for Multi Room With Minimum Cables
Do you want MultiRoom or just to run two TVs from a single cable TV box?
If the former, you need a second cable TV box at the second TV and all cable TV boxes require a cable co-ax connection.
  • 13.66K
  • 1.43K
  • 2.89K
Thanks in advance.
Cable TV is not IPTV. It is Broadcast TV, so the boxes receive all 250+ channels all the time. This requires huge bandwidth so a direct coax connection is the only option available. With V6 boxes the internet requirements of the box can be wireless, but even this is dependent on a good connection.
Cable customer since 1993. Services: FH TV, Sky Sports & Movies (2xV6), Talk Anytime Phone, VIVID 350, Virgin PAYG Mobile
