  • 49
stuey1
Message 1 of 5
E4 signal problems
Getting a pixelating problem on E4 channel. Only one i am aware of at present. How do i fix ?
  • 578
  • 58
  • 128
Cueball99
Rising star
Message 2 of 5
Re: E4 signal problems
Sounds like a signal issue. Call 150 to report a fault.
You may also want to check your service status to see if it's a know issue in your area.
  • 49
stuey1
Message 3 of 5
Cheers,will do. Been like it for a while now
  • 9.07K
  • 248
  • 545
Forum Team (Retired) Nat_J
Message 4 of 5
Sorry to hear this stuey1,
I've located your details and there are some SNR signal level issues present that I'd like for an engineer to rectify.
I've sent you a private message so that we can get this arranged.
Speak soon,
Nat_J
  • 49
stuey1
Message 5 of 5
Hi, can you explain briefly what the snr issues are exactly as i have had a quick look on diagnostics and levels appear to be above the recomended minimum levels.
Stuart
