Beeswing1
  • 12
BBC iplayer sound but no vision
When I try to watch iplayer through the VM app, I can see the load screen and the menu screen but when I select a program to watch I get sound but a black screen. I then have to turn the TV off and back in to watch the program. All other apps such as Netflix and Amazon Prime are fine. The TV is a Sony Bravia and the latest Android model. Please help!
  • 6.48K
  • 1.01K
  • 1.6K
Re: BBC iplayer sound but no vision
Hi Beeswing1,
What happens if you access the iplayer via the red button from a BBC channel?
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
