  • 9
  • 8
Liz2409
Message 11 of 18
Re: Will sound bar help poor quality V6 box
Yes, many times but still no improvement
  • 9
  • 8
Liz2409
Message 12 of 18
Pretty sure it is the V6 box as the problem is the same even when used with another tv
  • 9
  • 8
Liz2409
Message 13 of 18
Thanks Djuro, will give one a try!
  • 945
  • 79
  • 128
michaeldavis
Well-informed
Message 14 of 18
On some TV's the Surround Sound setting causes a muting of the sound.
If you do not have or are not utilizing a surround sound system then the following are generally the best options
Sound Effect - Standard
Simulated stereo setting  - On
Duel Sound - Stereo
Auto Volume - Off
Speaker - TV Speaker
Set the Treble, Bass and Balance to their mid points
Leave the Audio settings on the V6 box on Dolby Digital to PCM
Going back to basics and getting the settings maximized for a given TV using its internal speakers, has the advantage of knowing that you can then add a sound bar and make a couple of changes and easily hear the differences.
You can't learn anything from a mistake until you admit that you've made it.
  • 28
djurornic
Message 15 of 18
  • 828
  • 26
  • 47
Message 16 of 18
Hi Liz2409
Thanks for getting in touch.
Just wanted to check in and see if you have seen any improvements on the back of some of the suggestions offered?
Let us know if you require any further assistance 🙂
Nat
  • 9
  • 8
Liz2409
Message 17 of 18
Dear Nat,
no, the sound quality is still shockingly poor
regards,
Liz
  • 1.35K
  • 59
  • 105
Message 18 of 18
Hello Liz2409,
When you say the sound quality is poor do you mean quiet, What is the quality like via another device a Blu-Ray perhaps?
Thanks Joe_F
