  • 652
  • 65
  • 201
backtothefuture
Rising star
Message 71 of 191
Re: V6 volume too low.
I thought it was just me - after all this time found this thread!
If I have helped please feel free to give 'Kudos' by clicking on the thumbs up icon against any of my posts. If I have helped to solve an issue you can also click on the 'Mark As Helpful Answer' link to mark it as helpful.
  • 48
  • 39
Jamesy1234
Dialled in
Message 72 of 191
If there are any mods out there still bothered? This thread was started in 2017, it is now 2019!!!! "If" VM are "Looking into this issue" please explain why it is taking so long?
  • 273
  • 26
teamfloyduk
Up to speed
Message 73 of 191
Hi All,
I've just found this thread after having volume issues on the V6 box.
I have a Canton DM75 Sound base connected via a Toslink Digital Audio Optical cable to the TV, and had been looking at getting a splitter so that i could connect to the V6 Toslink socket as well to try and eliminate this problem, but looks like that wouldn't solve it.
As an added question would I get better sound quality connecting the sound base to the V6 Toslink socket direct rather than via the TV?
Cheers TF
  • 11
Jboss87
Message 74 of 191
Re: increasing source input on amp (sorry quote didn’t work)
Thanks hadn’t realised that was an option. Can increase the input up to 12db on the amp, probably going for +9
  • 9
  • 8
Liz2409
Message 75 of 191
Absolutely, they’ve got our money so they are not the slightest bit interested- customer service is not in their vocabulary
@davedicko wrote:
I think Virgin are hoping we'll go away!!!!!!Smiley Mad
  • 6
  • 6
Scottmcmullan8
Message 76 of 191
So I have had this same issue for over a year now. Tried everything and nothing work.
Purchased the Samsung NU8000 and it is the same with this tv.  I have to have the sound up to 23 or 24 for virgin everything else is between 10 and 12.
The tv was so good u recommend it to my mum. She got same tv and the same v6 box installed last week. I set up the tv and have to turn the volume to 53 to have it the same as mine on 23. Then the other apps r blasting out . It's pretty ridiculous that a simple firmware upgrade could fix this and that this thread is almost 2 years old !
  • 2.19K
  • 321
  • 569
av-115
Problem sorter
Message 77 of 191
If your mum has an identical setup, then there is something different in the settings either on the V6 or the TV. The first thing I would check is that her V6 is set to output "Dolby Digital to PCM" especially as you've mentioned the apps are louder. If that doesn't work, it would have to be something in the TV's audio settings. It's an identical setup so the volume levels should be the same as they are on your own TV.
TV: XL TV (V6 & V+ HD)
Broadband: VIVID 200
Phone: Talk Unlimited
  • 6
  • 6
Scottmcmullan8
Message 78 of 191
I'll Try this and see but to be fair the other apps like Netflix and YouTube have no issues.
But even my own setup the v6 box is terribly low. Still need a fixed from virgin and it's awful customer service
  • 2.19K
  • 321
  • 569
av-115
Problem sorter
Message 79 of 191
Yeah I'm not denying that there's an issue, I'm fortunate enough to have an AVR so I've gotten around it by increasing the source level so my V6 is in line with my other devices. But the problem should not be any worse with your mum's setup if she has the exact same TV as yours, so something else is going on there.
  • 18
  • 7
Rbrookbanks
Message 80 of 191
My workaround is to use HDMI from the V6 to the TV then take an optical signal from the TV to my AV Receiver.
The quality straight from the optical out is woeful.
