on 22-05-2022 11:31
Pressing digits on remote enters digit twice or moves placement twice making it impossible to enter codes , hit correct tabs etc . Have changed batteries and wiped down remote. Also tried to reset and pair again but need to be able to set code and problem makes this impossible. Any help out there
on 22-05-2022 13:38
@Suzanne23 wrote:Pressing digits on remote enters digit twice or moves placement twice
Sounds like something caught under the keys and double-entry is the result.
Try ordering a replacement remote here , and the TV Control app on a compatible mobile device as an interim measure.
on 24-05-2022 13:50
Hi Suzanne23,
Thanks for posting and welcome to our community 🙂
Sorry to hear you've had some trouble with the remote, have you been able to order a new one following the link from japitts?
If you do still need help with this please let us know.
Alex_Rm
