  • 4.65K
  • 314
  • 776
Roger_Gooner
Superstar
Message 21 of 37
Re: Using Virgin TV Go on a Samsung Smart TV
Use BBC iPlayer if you've a recent Samsung TV.
https://www.bbc.co.uk/iplayer/help/Samsung
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 945
  • 79
  • 131
michaeldavis
Well-informed
Message 22 of 37
I do find this rather amusing :
"Not a great endorsement of Virgin! Pure greed! For what you have to pay, they could at least allow one of the TV Go devices to be a smart tv."
A TV Go device to be a smart TV, that supposes that you can carry about a TV from room to room or when you are out and about. The app is intended for portable devices, not for TV's smart or otherwise.
I can just imagine the next complaint "Why can I not watch my 60 inch smart TV when I am in the supermarket, Virgin get your act together and get this sorted out"  PMSL
You can't learn anything from a mistake until you admit that you've made it.
  • 9
LouisYO30
Message 23 of 37
Loving the lack of positivity on here! If you had read my use case, you would understand why I wanted it, but please don't let it stop you from having a pop!
Once my contract is up, I will not be renewing with Virgin.
  • 8.09K
  • 427
  • 1.15K
PrinterElf
Message 24 of 37
@LouisYO30 wrote:
I would be prepared to pay a small fee for this.
The "small fee" you pay for this is the additional multi-room subscription.
That said, according to the BBC you should be able to set your TV's iPlayer app to your local region which may eliminate the issue.
Or, if you're resigning yourself to running coax from the nearest aerial point, why not instead run an HDMI cable from the nearest V6 box with using a splitter?
  • 9
LouisYO30
Message 25 of 37
Thanks. I thought about running a cable from the V6 box, but it's not practical. Would need to take up floorboards and drill through 12" walls. Also, I've heard this is not a workable solution.
  • 8.09K
  • 427
  • 1.15K
PrinterElf
Message 26 of 37
Wireless HDMI sender?
  • 9
LouisYO30
Message 27 of 37
Not heard of that one. How would it work?
  • 26.26K
  • 1.12K
  • 4.33K
Message 28 of 37
wireless HDMI senders cost £100 if not £1000'd
Click to learn more about VIP
Use Kudos to say thanks
  • 8.09K
  • 427
  • 1.15K
PrinterElf
Message 29 of 37
HDMI in from a splitter, then sends wirelessly to the receiver which you plug into the TV.
Not a clue on cost/effectiveness, as with anything wireless it's subject to environment. Which is why I originally suggested just a long cable.
Supasparks
Message 30 of 37
Instead of using a laptop, i use an android box (minix neo x8-h) works perfectly and hidden behind my Samsung 55” oled tv in my caravan in wales, vm box at home.
i refuse to pay twice for anything!
