ric5
USB power output on V6
If a V6 box is switched off, does the USB power output also switch off?
  • 25.05K
  • 1.04K
  • 3.98K
Re: USB power output on V6
plug something in to see Smiley Happy
  • 945
  • 79
  • 126
michaeldavis
Well-informed
The USB port on the V6 box is only a powered output port, so if the V6 powered down it will also power down
You can't learn anything from a mistake until you admit that you've made it.
