Max135
Surround sound
I have a Sony amp 7.1 sound system connected to my v6 box , the sound is dull and muffled.
Previously had it connected to sky box the sound was perfect anybody else had these issues
  • 3.52K
  • 227
  • 549
ozsat
Wise owl
Re: Surround sound
you have set the audio settings on the V6 to Dolby Digital and NOT PCM ?
V6 TiVo (with MRS & UHD/HDR)
VIVID 500 (500/35mb) in Area 31
SkyQ Silver Bundle (UHD + 2 minis)
  • 106
Re: Surround sound
Hi, Max135.
Thanks for your post and welcome to the community. 🙂
Sorry to hear you're having audio issues.
@ozsat is right, when your box is connected to your surround sound system, audio setting should be on Dolby Digital.
To change it, you can follow the instructions here.
Hope this helps.
Kind Regards,
Chai_S
  • 30
mcmav
Re: Surround sound
Just be aware you might get hte audio dropping when you change channels. I had that when connected to my yamaha amp. Leaving it on PCM is the only way it stops happening
  • 4.43K
  • 297
  • 742
Roger_Gooner
Community elder
Re: Surround sound
VM's PCM is stereo-only, so not suitable for those with surround-sound systems.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 30
mcmav
Re: Surround sound
I now so you have to virtualise the surround sound on the amp. Since the majority of Virgins audio signals are stereo anyway its not such a big problem.
