Whitty0922
Remote won't connect to TV
Hi I need some help. My virgin remote won't control my TV to turn it On or off or Controll the volume I have tried all the codes for my TV make which is Baird. I'm wondering if anyone could help. Also my TV that I have upstairs won't connect to the virgin remote aswell to Controll the volume or turn it off and on the TV make for that is bush I have tried all the codes for that aswell.
Ash
  • 790
  • 26
  • 61
Re: Remote won't connect to TV
Hello Whitty0922,
I am sorry to hear you are unable to do this, have you checked all the codes here too?
Baird TV Codes - 0023,0074,0102,014,0165,0182,0209,0218,0233,0379,0409
If none of these work, unfortunately the TV would not be supported at this current time, the codes I have provided are the only ones we have at the moment.
Thanks Joe_F
