on 21-09-2021 20:48
Trying to watch swat on sky max through the search function, but getting error 408.
It was working at the weekend, but no longer. Tested using Supergirl as it is the same channel, but get the same error, although searching gold rush and selecting an episode works, this is on discovery.
Jim
on 21-09-2021 21:50
Are there any specific individual episodes you're having problems with?
I've just played one episode of SWAT picked completely at random, and it plays fine.
on 21-09-2021 22:12
Hi Jim,
Have you checked for any local errors using Check My Service Status as per https://www.virginmedia.com/help/virgin-tv-error-codes/408
Or called the automated Service Status number on 0800 561 0061. This often gives details of more local issues down to postcode level.
on 22-09-2021 15:30
It happens on the episodes I have tried with swat season 4, even the early episodes I watched over the weekend, so no idea what is happening.
on 22-09-2021 15:43
@j1mgg1980 wrote:It happens on the episodes I have tried with swat season 4.
Which ones - can you be specific?
It will help others (myself included) to try watching the same episodes and see if we get the same issue.
Is anything reported on either the website or automated status line?
on 24-09-2021 15:52
Hi @j1mgg1980,
Welcome back to our Community Forums! Thank you for your post, and I'm sorry to hear that you're experiencing some TV errors when watching TV shows on demand!
I understand that this is not ideal and we'll be more than happy to help with this issue. 🙂
As @japitts suggested, please provide the exact episode that you're having issues with so we can see if we're able to recreate this issue and assist further.
Can you tell us if you've been able to reboot your TV box to see if this has cleared any issues?
Keep us updated if you can.
Thank you,
on 24-09-2021 16:05
Hi All,
Thanks for the advice, but this seems to have resolved itself, and I can join watch season 4 ep 1-6
on 27-09-2021 10:43
Hi @j1mgg1980
Thanks very much for popping back to let us know. I'm glad to hear the issues is now resolved 🙂
If there's anything else you need, please do let us know and we would be happy to help!
Kind regards,
Serena
