on 18-10-2021 19:11
Sky max works fine but when I try and watch Sky Max on Demand there is no sound.
When I try and select something other than UHD e.g. HD or SD it defaults back to UHD.
The TV is one of the latest Philips ambiilight LED models. Anyone finding the same problem?
The sound on the v6 is set to PCM.
on 18-10-2021 19:21
on 18-10-2021 19:56
@martyk57 wrote:Sky max works fine but when I try and watch Sky Max on Demand there is no sound.
What's your video output settings? This almost sounds like your TV is reporting a 2160 input regardless of the source material, and your V6 is upscaling all 576 & 1080 content to 2160 - that's epected behaviour.
As for your lack of sound, does this affect any other channels/programmes? There's nothing different about Sky Max OnDemand compared with any other OnDemand content - they use the same delivery mechanism.
on 26-10-2021 08:37
Everytime virgin media change something they reset all the video settings 2160p so I have to reset everything.Generally I have it set for 2160p pass through 1080p passthrough and 1080i.All live tv streaming is nearly all 1080i, I let our tv do any upscaling as it does a far better job. In this case I had left 2160p checked so unchecked it and the sound returned.
virgin used to have a habit of changing the frame rate to something non standard..(see some of the older posts) not sure how it is now. We have a 7.1 channel amp so we always have the sound set to PCM and let the amp manage the sound distribution.
thanks to you both for your replies.
on 26-10-2021 14:19
on 26-10-2021 14:59
Hi marty
Regarding your sound output, As I said previously, you need to set the output to 'Dolby Digital' ...
I have a Bose 7.1 surround system, and if you have the output set to PCM, as LittleMick73 has stated, you will still get 7 points or origin for the sound output, but all 7 speakers will be giving the same output, rather than 7 individual audio channels, thus not true surround.
The playback fault could have been a one-off issue.
Regarding video: If you are watching a program/episode via 'On Demand' it should playback at whatever it was originally broadcast at, ie: if it was an SD program, it should playback via 'On Demand' at SD ...That said, your V6 and your TV have the ability to upscale, so it is plausible that the TV has upscaled to playback at 2160p.
Regards,
on 26-10-2021 15:56
Does this issue affect any other channels/programmes?
As mentioned above, there's nothing different about Sky Max OnDemand compared with any other OnDemand content - they use the same delivery mechanism.
It seems from the replies thus far, this is a general problem with your sound, affecting VOD & live TV equally?
on 28-10-2021 16:17
