  • 8
posty
Message 1 of 12
How to set my audio settings to 5.1
As above can the V6 support DD 5.1 audio through a separate amp via a optical cable, Netflix played through my smart tv does but not through the V 6
  • 154
  • 13
  • 38
techifan
Superfast
Message 2 of 12
Re: How to set my audio settings to 5.1
Help & settings
Settings
audio
dolby digital
If a channel is broadcasting a 5.1 feed this setting gives me 5.1 via hdmi connected to my sound bar but should also be good for optical to.
  • 3.19K
  • 217
  • 508
Roger_Gooner
Wise owl
Message 3 of 12
A TOSLINK cable between the V6 and amp will carry 5.1 audio.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 8
posty
Message 4 of 12
Ok so I changed the settings on the V6 as instructed played a movie on Netflix through the V6 no DD5.1 played the same movie through my Panasonic smart TV perfect DD5.1 I don't understand
  • 3.19K
  • 217
  • 508
Roger_Gooner
Wise owl
Message 5 of 12
How did you get 5.1 from your TV?
  • 3.33K
  • 207
  • 485
ozsat
Wise owl
Message 6 of 12
How is this all connect up?  Does the V6 audio go via the tv?
Al ot of tv's will do 5.1 output if from their own tuner or apps - but will not pass-thru 5.1 audio when it is from a HDMI source.
V6 TiVo (with MRS & UHD/HDR)
VIVID 500 (500/35mb) in Area 31
SkyQ Silver Bundle (UHD + 2 minis)
  • 8
posty
Message 7 of 12
Via an optical cable to a surround system I play the V6 through the same system so basically all audio comes through that
  • 3.19K
  • 217
  • 508
Roger_Gooner
Wise owl
Message 8 of 12
The only guaranteed way to get 5.1 audio is from the V6 to your amp. Should you swap your amp for an AVR, then V6 ---> AVR ---> TV by HDMI cables will work so long as you don't run into HDCP 2.2 problems.
  • 8
posty
Message 9 of 12
If I can get 5.1 from my tv via an optical cable to a surround system then in simple terms why will 5.1 not work from a V6 box via an optical cable to my surround system, all my audio either from tv or V6 goes through the optical cable its only 5.1 from the V6 that I cant get
  • 3.19K
  • 217
  • 508
Roger_Gooner
Wise owl
Message 10 of 12
I misunderstood you. You ought to get 5.1 from the V6 to the amp, can't explain why this doesn't work unless the TOSLINK is faulty.
