Hi @jp258
regarding "the box freezing when navigating the guide, sometimes for a few seconds, sometimes for a minute"
When that happens I shake my remote and it starts responding again.
Error CS2318 says call in so VM can send a signal, I don't believe that will help.
@jp258 and @deantiller
The Guide losing icons and substituting text would appear to be an internet connection issue, I would imagine if you looked at the Box Sets & Movies section there would be a good number of items without the graphic showing.
The other issues may be caused by faulty ports on the 360, a faulty hard drive, or signal issues.
Under Settings > Network> Diagnostics the top section shows the signal quality to the various boxes, I would imagine when you are having problems there would be crosses against some of the icons there. And scrolling further down the screen and looking at Connection speed I would image that instead of showing High or Good it would have a cross against either Live TV (HD) Wathc All (HD) or Watch All (UHD) there would be at least one cross.
I beleive you both need a tech visit to check connections and possibly change the 360.
DaveI don't work for Virgin Media.
The do's and don'ts. Keep the community welcoming for all.
Follow the house rules The Service you do for others is the rent you pay for your room here on Earth - Muhammad AliLove, love and love, forever - Pele
