on 10-12-2022 11:15
I switched over to a 360 box about 2 months ago and haven't had any major problems (except getting intermittent black screens for 2/3 seconds at a regularly which i haven't solved yet!). My wife accidentally powered down the box a couple of days ago and on switching it back on, it seems to be stuck trying to boot. I've tried switching it off/unplugging etc and it's always the same sequence:
Power On --> Standby (Red) - 30 seconds --> Booting (Amber)
Once the boot sequence starts, my TV shows
Tuner 1 --> Tuner 1(Virgin TV 2)
And the nothing else happens.
I've seen others on the forum with this problem, is it an engineer or can i try anything else before this?
Answered! Go to Answer
on 10-12-2022 12:18
All sorted - after i took a closer look, it seemed that the coax cable had been knocked whilst she was trying to get it back working - a quick tightening up has sorted it out.
on 10-12-2022 12:18
on 13-12-2022 10:22
Hi @bod1611
Thanks for updating the thread, pleased to see you've found the cause and it's all working now.
It's easily done and something we tend to overlook, so your solution should help others too.
on 15-12-2022 11:11
Hi @bod1611,
Welcome back to our community forums and sorry to hear you had issues with your TV box.
We are however glad to see the issue was resolved by securing a cable. In this case, please continue to monitor your service and let us know if you need any further help.
