on 21-04-2021 21:45
on 28-03-2022 14:59
only sky news & channel 4.
on 30-03-2022 15:53
Thanks for confirming that @jimboy56
@miles5759 can I just check if you're also experiencing issues with these channels?
The more info we have will allow us to feedback to the backend teams if required.
on 30-03-2022 16:16
My issue is on hdmi 1 which has virgin 360 box on it, so all the channels.
on 01-04-2022 18:53
Hi miles5759,
Thanks for letting us know. You mentioned the issue is on HDMi 1, can you just clarify whether you mean the issue is with your TV box or through this HDMi port? What happens when you try the TV box in a different HDMi port?
on 01-04-2022 19:08
Hi Beth
I answer that question much further up in the message threads, last year.
But the issue is not channel related for me. I have a Virgin 360 box, and the issue happens no matter what channel I watch on Virgin.
It also happens if I watch a DVD via a different HDMI port.
The problem went away when I upgraded my TVs firmware. But it came back mid Feb.
Miles
on 04-04-2022 08:44
Thanks for coming back to us @miles5759, have you contacted your TV manufacturer to look into this issue, if its affecting your DVD player as well?
Regards,
Steven_L
on 29-11-2022 13:39
Recently changed (upgraded?) to TV 360 and finding issues with the sound although so far this has been garbled sound rather than a cutting out. I have tried various steps as recommended in these messages and have not solved the problem. I have discovered today that if I rewind the programme a few seconds and then play again the sound is no longer garbled and maintains this when returning to actual time.
I would also add that this only appears to be a problem on the box connected to the TV with a Sonos soundbar. Although not watched as much the second TV which only uses the TV speakers has not shown any sign of having this issue.
on 01-12-2022 14:04
Do the issue happen if the Sonos soundbar isn't connected at all PG66? Just trying to narrow down the possible causes.
Rob
on 01-12-2022 14:30
Hi @PG66
Have you tried setting the video on the 360 box to 1080i or 1080p?
Also have you tried altering the following?
Settings > Audio & Video > Audio output
Follow Content
PCM 5.1 (HDMI only)
PCM 2.0
Choose whether you want the audio output to follow the quality of the original content (Dolby Digital where available) or to be converted to PCM 2.0 (stereo) or PCM 5.1 (uncompressed multi channel sound). Using PCM settings may resolve audio sync issues. Netflix will always follow content.
I hope this particular highlighted post will be helpful Sonos-Beam-Sound-dropping-out-with-Virgin-360
I don't know if you are using the VM wifi pods, but if you are then please read the following as it may help with wifi connections
Sonos speakers
Try to keep your Sonos speakers at least three feet away from the mesh WiFi Pod and other devices. Also check for updates to make sure your speakers have the latest firmware installed.
Only connect one Sonos device – Sonos speaker, Sonos Connect or Sonos Boost – using the Ethernet on the mesh WiFi Pod. Your Sonos system should then create its own network that works across your WiFi.
on 01-12-2022 14:54
I am currently trying using only amplifier on the soundbar with the TV amplifier turned down to zero. So far this has worked for a couple of hours so want to try for longer before claiming the issue is resolved.
