on 30-12-2022 18:46
Since upgrading to the new hub I’m unable to connect either my Sonos arc or Sonos base unit to the new Wi-Fi via the Sonos app. It can find both products and the Wi-Fi but when I enter the password it’s does not recognise it. Anyone else had this issue? Any suggestions on how to resolve it?
on 30-12-2022 18:50
Correction. It’s the Hub 5 not 4
on 30-12-2022 20:52
on 30-12-2022 23:04
Yes it is.
on 02-01-2023 13:21
Hi digitalchica,
Thank you for reaching out to us in our community and welcome, sorry to hear you are facing issues setting up yopur Sonos speaklers since upgrading to our Hub 5.0, have you tried the Sonos support Forums to see if anyone else has had the same issues?
Paul.
on 02-01-2023 13:31
I just had a look on the Sonos forum (thanks for the suggestion) and they are saying to switch it to modem mode. Any ideas about how this is different from the current factory settings? Not really clued up on this. I did find a video to change to Modem mode but don't want to attempt it yet in case I can revert it back to the original settings if it does not work.
on 02-01-2023 14:54
on 04-01-2023 14:59
Thanks for coming back to us @digitalchica, can you please confirm if you've been able to find a solution to this issue?
Placing the hub in modem mode, as @Roger_Gooner advises, this would not allow you to use a Wi-Fi service on our router.
Kindest regards,
David_Bn
on 04-01-2023 16:29
@digitalchica wrote:Since upgrading to the new hub I’m unable to connect either my Sonos arc or Sonos base unit to the new Wi-Fi via the Sonos app. It can find both products and the Wi-Fi but when I enter the password it’s does not recognise it. Anyone else had this issue? Any suggestions on how to resolve it?
Some things to consider are:
If these fail hopefully the Sonos forums may provide the answer you need.
on 06-01-2023 21:53
I managed to resolve the issue with Sonos help. It was because my system was still connected to the ole Wi-Fi network from the original hub that was replaced with the Hub 5. They were extremely helpful. Thank you all who responded. 🙂
