on 05-09-2021 20:44
The picture quality it’s noticeably worse on the new Sky Max channel than the other channels like Sky Showcase (which I assume was just the same old sky1 feed with sky max being a new feed)
It looks like it’s using a really low bit rate, it’s hideous. Is this a local issue or is anyone else experiencing this?
on 05-09-2021 20:54
I don't have the SD channel but the HD version looks OK.
on 05-09-2021 21:28
It's not a bitrate issue, if anything Sky Max SD has a fractionally higher bitrate than Sky Showcase SD (credit DBR)
It doesn't seem any different to other Sky SD channels IMO - I'm using a V6 though, and have the HD version.
on 06-09-2021 18:03
Sky Max SD is noticeably worse than sky Showcase here. I don’t have access to HD versions so strictly talking about SD here.
Do we have information that it’s a higher bit rate it certainly doesn’t look that way, it’s extremely pixelated.
The way Sky Showcase is designed last night it was showing the same show as Sky Max and you could see a huge difference, I’d go as far as saying there’s a fault.
Maybe a localised issue Virgin need to look into?
on 06-09-2021 18:08
@ashscrivens1 wrote:Do we have information that it’s a higher bit rate it certainly doesn’t look that way, it’s extremely pixelated.
Pixellation & picture breakup is a different thing, and is indicative of a signal fault.
ITV2 & ITV4 SD are both on the same broadcast frequency as Sky Arts SD and are in the same package tiers. If you have a signal fault affecting Sky Arts SD, it should affect those 2 equally. There's several more, but those are the obvious ones to check.
on 06-09-2021 18:12
It doesn’t look as bad through a phone camera however you can see some picture breakup and the whole picture is generally more pixelated than anything I’ve seen on Virgin.
you can hardly read any wording on screen
just to point out the rest of my Virgin is fine, it’s this one channel
on 06-09-2021 18:17
ITV 2 seems fine
Sky arts has a pretty poor quality also compared to sky showcase
During adverts is the best test I find as it’s usually the same ads and small print on ads becomes unreadable.
on 06-09-2021 18:29
Sky Max SD is on the same mux as Sky Documentaries, Comedy Central and horror channel, so if you get problems on those channels it will most likely be a signal fault like japitts has said.
on 06-09-2021 18:57
Well spotted that I'd quoted the mux details for Sky Arts, while the thread is about Sky Max. That's what comes of multi-tasking...
Apologies - Take my theory but roy's observations. Looking at the mux details and having half a mind as to package availability, it's also worth checking Box Hits & The Box (music channels)
on 08-09-2021 19:11
Hi @ashscriven1,
Welcome to our Community Forums and thanks for your post.
Sorry to hear you're having some issues with picture quality. Can you confirm if you're having problems on any other channels?
Kind Regards,
