on 17-11-2022 15:08
Hi, I'm appealing for clear information on how to link my Virgin 360 (ex-V6 but upgraded to 360) box in second room for live TV.
I have a mesh set up through the flat and have excellent speeds via the Virgin service.
The live TV works fine in the main room next to the router and TV hub, but in spite of what the agent told me when I signed up for the 360 upgrade that the primary and second boxes could communicate through my network with ethernet connections to the mesh hubs, I can't get live TV on the second box.
Reviewing this forum, it's now clear that I was misled and that I need a coax cable into the second box for live TV.
I have no coax wall output in the second room, and according to another agent, a Virgin engineer needs to come and install a connection from the TV hub to the second box via splitters etc.
The second room is about 70 metres from the hub divided by 2 walls.
How on earth can they run a cable without creating an unsightly mess in the premises I'm currently renting?
I am about to move back to my permanent address (currently in renovation) in a few months and want to pre-install the appropriate coax cables under the floorboards to ensure the right set up.
My electrician/arial installer can do this but needs precise guidance as to how Virgin connect the boxes.
I've searched high and low on the internet for instructions, but can't find anything.
Sorry for length of this, but any guidance would be much appreciated.
Thanks.
Answered! Go to Answer
on 17-11-2022 15:50
If the property has a detached end it's sometimes possible to run the coaxial cable round the side of the building, otherwise it has to be an internal job. For internal installation the walls have to be drilled through unless the cable can be run under the floorboards. There is a further consideration that as the 360 requires a network connection, you should be installing an Ethernet cable (can be run alongside the coaxial cable).
You should consult your landlord about the work required. If he agrees to it then the best thing would be to get the Ethernet cable installed in advance and, for an internal installation, install a pull cord for the coaxial cable.
on 17-11-2022 15:50
on 17-11-2022 15:57
@sigo23 wrote:I am about to move back to my permanent address (currently in renovation) in a few months and want to pre-install the appropriate coax cables under the floorboards to ensure the right set up.
Thanks.
You can't find Virgin's cabling for sale as it is specifically made for them. VM techs will not connect up anything else as connecting non-standard cable can cause serious network issues for the entire street, so a DIY job will be a waste of your money. Install ducting & pull ropes so that the necessary cabling can be pulled on the day.
on 18-11-2022 13:18
Hi, was this sorted for you?
I had the same problem being told by an agent my second box could be connected via wi-fi for live tv viewing on the second box. Grrrrr.
I'm upgrading flooring in my flat and want to know whether I should bury conduit between primary TV hub and outlet in second room (about 80 metres away) before I call out an engineer to reinstall equipment.
I absolutely don't want ugly wiring around skirting boards and holes drilled in walls if I in advance avoid it by providing provision for 'hidden' cabling.
No-one at the call centre could help me, I've filed a 'complaint' and await a call back from a manager.
Fingers crossed
on 18-11-2022 13:38
Bothe nodrogd and Roger_Gooner have since helpfully answered my original question, thanks both.
on 18-11-2022 17:24
on 19-11-2022 06:40
All my Virgin boxes are running with prewired 2006 coax that we installed back then. Luckily I had the insight to install ethernet. When VM came to do my pre install they have me the RG6 cable to run from the loft to the front of my house as I didn’t want any drilling. Everything works fine.
