Problems with 360/hub3 in modem mode
wadouglas
Hi, I am looking for help with my set up please.
I have had vm broadband on the hub 3 for several years….due to thick walls etc I use it in modem mode and use a mesh for wifi and had no problems. I recently added basic tv to the package and was sent a 360 box with a splitter. When I set it up the hub flashes green, which I understand indicates an update, but after leaving it for many hours nothing changed. With the splitter in I get tv but can’t get the modem/mesh set up to work. Could I have a faulty splitter?
1 ACCEPTED SOLUTION
Accepted Solutions
nodrogd
If the hub base light flashes green constantly you have a signal issue. Adding the splitter & additional cable has likely put your signal levels out of spec. Check the connections are in firmly. If they are then ring faults, as a technician will be required to open the street cabinet & boost the signal to your line.
If the hub cycles between a flashing & steady base light there is an account error which needs rectifying.
VM 350BB 2xV6 & Landline. Freeview/Freesat HD, ASDA/Tesco PAYG Mobile. Cable customer since 1993
2 REPLIES 2
nodrogd
Thanks for the reply nodrogd, I checked the connections and no change so have a technician coming out this week.
