on 25-02-2021 20:43
Is there a way to get to the top of the guide quickly, rather than have to scroll through?
on 25-02-2021 20:47
Hi there
If you press the round Home Button (with the House) that will take you to the Date
If you press the Guide Button (just to the left of the Home button) this should take you to the top of TV guide
Christy
25-02-2021 20:53 - edited 25-02-2021 21:03
The quickest way to get to the top of the guide is to press the mic button and say "top" or the name of the channel you want to go to e.g."BBC1"
Pressing the "Home" button whilst in the guide will take you to the date field but pressing the guide button, contrary to what was said in the previous post, will on the first press take you back to where you entered the guide. So if it was, say, ITV2 you were watching when you hit the guide button you would enter the guide at the line for ITV2. If you then scrolled through the guide pressing the guide button will take you back to the line for ITV2. A second press will exit the guide.
on 25-02-2021 23:31
Least amount of buttons to press and not speak is just to press 1, that will take you to the top, or if you want to go to the top of movies press 401 and sport 501.
