on 23-01-2023 22:37
Hi all, just got connected with Virgin after moving from sky.
mostly going great (though noticeable that the wifi struggles to reach parts of the house sky did - but an extender should solve that). Anyway, we have a 49in Toshiba TV, about 2 years old. And no attempt successfully pairs this tv with the remote for volume control.
has anyone any ideas on similar makes that may work to trick this into working? It doesn’t seem like 4 digit codes exist any more.
thanks
Answered! Go to Answer
on 23-01-2023 23:04
I assume you have gone through all the key testing methods and not found a match, if that's the case then your best bet is to provide the model number of the TV and see if that gets a response if someone has the same.
on 23-01-2023 23:04
on 24-01-2023 09:35
Thanks.
Model is a Toshiba 49inch 4k LED TV.
Don't have the specific model number to hand, but it starts 49V5...
on 24-01-2023 12:19
Hi @patomlin76
Try entering the first 4 characters after the screen size. In your case 49V5 you should enter V5xx where xx is the next two characters.
on 24-01-2023 12:20
Thanks will try that. I did 49V5 as the first four characters, but obviously that didn't work!
on 24-01-2023 12:23
on 24-01-2023 12:41
Almost, the model number looks almost the same but it’s probably the replacement model.
thanks
on 24-01-2023 13:04
I think this was for sale around 2018, you can try V586, or 5863.
on 24-01-2023 14:14
on 26-01-2023 15:51
Hi @patomlin76,
Welcome back to our community forums and sorry to hear you have been having issues when trying to pair the remote. We can understand the frustration caused. Have you been able to try the advice given by @ellistephen? Have you also tried as seen here https://www.youtube.com/watch?v=eSloQ7y6xkk ?
