on 19-10-2020 10:45
I have had the new V6 /360 box for 10 days and have problems with the audio synchronisation.
My TV is a 4 year old 50" Sony Bravia with Sony sound bar. When I had the Tivo and the model before it I never had any problems.
The audio is okay with the soundbar off but when using the soundbar the audio drifts after about 5 mins. I have tried Dolby On/Off settings , audio delay set to 20m/sec and follow audio On/Off. All work for 5 mins then drift.
I have telephoned Virgin on 2 occasions the 2nd time getting through to their 2nd tier support. Went through all the power down re-boot etc but still the same issues.
Anyone else have this problem and any suggestions?
Thnks
Answered! Go to Answer
on 17-01-2022 10:33
Is this something to do with the 360 software? I currently have a V6 box and experience no lip sync issues between the box, LG CX TV and Sonos Arc. The Netflix and Amazon apps work fine, but my problem is, no Dolby atmos is passed, I can only get atmos if I use the apps on the TV instead of the virgin box, which is why I started to think about 360 as I assumed this would fix the dolby issue. But by reading the 360 threads, it looks like it might be a backward step and I might just ignore the upgrade and just stick to using the apps on the TV
on 17-01-2022 11:04
For me, the Dolby Audio works fine for the apps on the 360 box (Netflix and Amazon Prime) but not for TV channels (or recordings) passed via HDMI ARC.
If it were me, of stock to using the TV's built in apps instead.
I also have an issue where Netflix always shows a black screen after a few seconds of starting any stream. I believe this has been documented elsewhere but never fixed.
on 17-01-2022 11:22
@luk34dd0 wrote:I also have an issue where Netflix always shows a black screen after a few seconds of starting any stream. I believe this has been documented elsewhere but never fixed.
I believe the black screen is caused by the "Match framerate" option on the 360. Try with it turned off.
17-01-2022 11:24 - edited 17-01-2022 11:24
I'll try that, thanks.
Another option that we should be able to use without issues though.
on 17-01-2022 12:29
on 17-01-2022 23:42
If only a short blip when changing refresh rate it is unavoidable and isn't necessarily a sign something wrong with the 360. When refresh rate changes your TV will need to sync into that updated refresh rate.
Suspect it's why on the 360 they fix resolution to a single value.. Someone testing probably decided for themselves they didn't like that blip when switching between one resolution and refresh rate on menus and another on content so set box to output single resolution and rate always to avoid complaints. They probably didn't understand some people don't mind the blip to get both native resolution and native rates.
on 22-01-2022 15:50
Why is it acceptable to follow the stated Virgin resolution by switching of the Dolby (and thereby render any Dolby Audio system useless?). Virgin Media refuse to acknowledge that there is a problem with the 360 box and continues to falsely claim and promote it supports Dolby 5.1 etc. As stated before, Virgin this is Trades Descriptions Act!
on 27-01-2022 20:09
Just got 360 box today after cancelling Sky due to an overcharge, what a mistake that was. This is a nightmare.
on 27-01-2022 20:15
on 18-07-2022 09:54
Any update on this Virgin Media?
