b018998029
Just joined
BT 6600 Answer machine does not work properly
We recently bought a BT6600 phone with integral answer machine.
It works fine except when someone calls and the answer machine kicks in but they dont leave a message. The phone then gets stuck in a loop and permanently thinks the caller is leaving a message. As a result no one else can then call as they get the engaged tone.
If the caller leaves a message and then ends the call there is no problem. We called BT and they have stated this is a known problem with Virgin and the answer is to get Virgin to send an end pulse down the line.
We have spent 40 minutes this afternoon speaking 3 different people at Virgin and none of them understand the problem or what an end pulse is. Has anyone else had a similar problem?
  • 51
  • 6
  • 12
stoo_77
Dialled in
Re: BT 6600 Answer machine does not work properly
I have a Panasonic phone with integral answer phone and has never proved a problem on VM even if the caller does not leave a message.  I would think its maybe a faulty unit.
Stoo.
Broadband:- VIVID 200
TV:- Mix Tv (Tivo V6)
Phone:- Talk More Anytime
Mobile:- 2 x 30 day sim
  • 1.56K
  • 156
  • 274
LittleMick73
Super solver
I to have the same as stoo_77 and don't have any problems, sounds like a duff phone, not surprised that BT are trying to pass the buck. Regards Micky
Jeff7
I have had a similar problem with a BT answerphone, had the line checked by a Virgin engineer last week which confirmed everything was working but still had the problem of calls not clearing if the caller hung up while the outgoing message was playing. So I replaced the phone with another BT answerphone only to have the same result. I took this phone to my Mum who is on BT and it works perfectly - guess there must be something in the BT software which doesn't like Virgin (or vice versa). Previously had a Gigaset phone with no problem and now have a new Gigaset phone which works perfectly. The solution seems to be not to use a BT answerphone on a Virgin connection (at least for the time being).
VHolland
Did you ever get a resolution to your problem?  We've just bought a BT6600 cordless phone and we are having exactly the same problem.
  • 218
  • 9
  • 10
Hi VHolland,
Welcome to the Forums - thanks for joining and making your first post Smiley Happy
This is not an issue that I have seen or heard of before - however we cannot comment on 3rd party equipment. Does the same issue happen using a different device?
Katie - Forum Team
