on 23-10-2021 15:28
I have just moved from android to Apple Iphone x. I can send texts but not receive them. Can anyone help please
on 23-10-2021 15:41
Hi blueskies76,
Thank you for getting in touch with us here on the community.
I am sorry to hear you are experiencing some issues with using your mobile service.
Are you having problems receiving messages from a particular number or from all numbers?
When was the SIM activating please? Also, do you have a strong signal?
Let us know and we will be happy to assist further.
on 23-10-2021 15:49
Its the same sim from my other handset, so been active a long time. I cannot receive from any number and yes I have a very strong signal
on 23-10-2021 15:56
Thank you for confirming.
Have you received any texts from ourselves since the SIM was inserted?
Are you able to make and receive calls please?
Nat
on 23-10-2021 16:01
I recieved one intially for mobile web, then nothing. I can make and recieve calls
on 23-10-2021 16:51
Can you try the SIM in a different device now for me to see if you can receive the texts after this?
on 23-10-2021 17:29
I put it back in my old phone and it was fine, I received a text. Then I put in back in the iphone and recieved one text. However it has not recieved a second one from another number
on 23-10-2021 17:40
Have you tried any other numbers besides from the one which doesn't work and the one what does work?
