Message 11 of 123
Re: iPhone Dial Assist Problems
Yes, I’ve turned Dial Assist off. I reset the regional settings yesterday, and by today the numbers have reverted to 2, 3, 2, 2, 2 format again. So I’m now making my way through my Contacts and pre-fixing all the UK numbers with +44.
  • 12
Message 12 of 123
Thanks for this its been driving me crazy 🙂 now works perfect, never been to Belgium 🙂
  • 5
  • 5
Message 13 of 123
Glad to have been of some help @kevinuk1 and having been to both Australia and Lanzarote  since this has not happened again! Most bizarre, know what you mean about driving you crazy though 😊
Just joined
Message 14 of 123
Did you manage to resolve the problem as I have exactly the same problem as you Nigel ?
Just joined
Message 15 of 123
I can't manage to even replace all of my contacts as they automatically put a space in when I type the number.
  • 5
  • 5
Message 16 of 123
Hi @rapond yes I did by setting my phone to Belgium then back to the UK and making sure dial assist is turned off. It then showed all my numbers in the correct format. Have been abroad since twice and not happened since.
hopefully this will work for you too 🙂
Carole
  • 16
Message 17 of 123
Hi carolanndrap
Like you, my wife and I both received a text from Virgin Mobile to download a file to configure the iPhone for internet connection.  We were in Cyprus at the time.  On arrival back in the UK we both had dialling assist problems which were easily resolved by disabling it.  However the problem with phone numbers in the wrong format has not been resolved permanently with any or all of the recommended fixes - changing region to non-UK then back to UK, power cycling, rebooting, checking contacts addresses have the correct country. only resolve the situation for a short while - sometimes a couple of times a day.
This is annoying for several reasons including the fact that incoming calls and texts do not show the senders name from Contacts.
I am of the opinion that it is the download file from Virgin that is the route of the problem.  Apple have note been helpful on this issue
Is there anyone else out there that has any alternative recommendations?
Unless anyone has other ideas my only recourse is to reset the iPhone to factory defaults and reinstall which is inconvenient and time consuming.
  • 25
  • 8
Message 18 of 123
There is a quick fix I’ve discovered but it’s not permanent for some reason. I’ve no idea why my iPhone is changing region, it’s happening many times a day.
the quick fix. Go in to Settings, go in to General, go in to Language and Region. You’ll probably find the region is still shown as UK, however the phone is set for elsewhere, in my case, it sets to Belgium, despite still showing UK. Select any other Region (I use Uruguay for ease) and set it. The screen will go black and “setting” will be displayed. It will then be set to Uruguay. Now reselect UK and set it. The screen will go black again and “setting” will be displayed. When complete, the Region will show UK. Your phone numbers will now be back to normal UK format.
As I said, this is not a permanent fix, for me any way. I have to repeat it a few times a day. Still searching for the glitch and a permanent solution.
Good luck!
  • 5.27K
  • 794
  • 1.43K
Message 19 of 123
Are they all saying Belgium? It's just that Virgin SIMs are programmed by Belgian Proximus. Just wondering if there is a correlation
  • 16
Message 20 of 123
My device always shows my region correctly as United Kingdom. I have altered to various other regions then back to UK and it fixes the problem but only temporarily.  I've noticed that there are several different iOS levels quoted. I'm om iOS 13.2 and in the process of currently updating to 13.2.1 - forever hopeful of an Apple bug fix,  Like an earlier post I was also out of the UK when I updated iOS, in my case to 13.1
