on 10-02-2022 21:45
i have a iPhone 13 pro that keeps changing my numbers in my contacts to Belgium numbers.
this happens even though the region is still set to United Kingdom. If I then change the region to Belgium, then back to UK it’s works for a day or 2 then goes back to Belgium numbers being displayed.
any ideas how I can stop this from happening?
many thanks
Answered! Go to Answer
on 10-02-2022 22:39
Hi @Dazpotter87
This has cropped up a lot on the mobile forums. The answer is to perform the following, making sure you reboot after making the changes :-
Reboot
on 10-02-2022 22:39
Hi @Dazpotter87
Reboot
on 12-02-2022 13:35
Hi Dazpotter87,
Thanks for posting and welcome to our community 🙂
Sorry to hear you've had some trouble with the region on your mobile, have you been able to try what newapollo has suggested?
Alex_Rm
