PMackC
Xperia 10 Wireless Charging
Hi, from looking at the spec tab for this phone I was under the impression that it was enabled for wireless charging (Qi) I bought 2 wireless charging pads yesterday and guess what, it doesn't work.
This spec is misleading.
Capacity
2870mAh
Wireless charging
Fast Battery charging 18W (Quick charge 3.0)
  • 2.74K
  • 357
  • 681
enlli
Trouble shooter
Re: Xperia 10 Wireless Charging
According to the specs I have seen the 10 and 10+ do not have wireless charging. But others say yes. Some confusion there.
PMackC
I've bought a little adaptor that fits in behind the phone and it works. I does generate a lot of heat though.
